Brief Description: Mid-Aft Body Join - Add Fwd Side Skins 3
Adding the co-pilot side skin was easier because I had the fuselage better positioned for the holes to line up. Also I started at the aft end. This works better. Start at the aft end and then do the forward clecos.
The longerons matched pretty well on this side to, except I removed a little of the twist. I can't really tell if the twist matches the skin because the skin is flopping around so more on that later.
