Brief Description: Mid-Aft Body Join - Mate Mid to AFt fuselage 1
After putting the longerons in place and securing them with clecoes and clamps I flipped the aft fuselage upside down. Then wife, Jody, helped me flip the mid section upside down and place it in position with the aft fusleage. It was pretty easy. The mid section rests on top of the aft section and the aft section slides into place.
I had to remove the cargo floors. You can't do this with those floors on because you can't see good enough and you need access to cleco the bulkheads together.
I got all the clecoes in. I used an awl to help line up holes.
