Brief Description: Mid Fuselage - Rivet on cargo ribs to bulkhead
Second major assembly step is to add the mid bulkhead and cargo ribs. I started in the center with the two inner most ribs. I looked at the drawing for each rivet to make sure I was using the right length. But it is kind of easy to see if the length of rivet that is revealed is appropriate or not.
I didn't have any trouble getting the rivet gun and bucking bar on the rivets. I used the angled end of the tungsten bar on the top rivets which were a little difficult to reach.
