Brief Description: Longerons - Trim Horizontal Face 1
I measured and marked the ends of the longerons for trimming per detail C on drawing 18. Notice dimensions given in (paranthesis) are approximate. The exact location of this cut out is determined off the hole in the aft deck. So I drew a line per distance called on the drawing and centered the aft deck hole on the line and drew the cut off line. I held the aft deck 1/8 from edge of longeron per drawing dimensions. I drilled the 1/8 diameter radius.
