Brief Description: F-712 Builhead - Start Make Tie Down
The F-712 bulkhead is just two plates and a tie down. I cut the tie down to size per drawing. Gotta have a bandsaw. I put threads in it. And drilled the 8 holes. I use that little 1/8 centering bit. It works great because I scribe the lines and the centering bit fits right into the cross hairs of the scribed lines for perfect hole location.
