Next I clecoed the whole thing together. I match drilled all the holes I could like corners and plate. I positioned the top and drilled those holes. Then I pondered the position of the longest angle and discovered its one drilled hole would cleco to the rib as a starting point. So then I drilled the rest of the holes including the 1/4 hole in this angle.
