Brief Description: F-704 Bulkhead - Putting two pieces together 2
I put the halves together with a couple bolts. I did not test fit all the bolts. They fit very very tight and I don't like playing with them. They will all go in, but I have to push and turn them.
I clecoed on the side plates and call it done. I did not match drill the side plates to the bulkhead uprights. They are primed. All bushings are installed. I'll store this in two halves and keep the bolts in my bolt box.
