Brief Description: F-704 Bulkhead - Putting two pieces together 1
The last thing to do for the 704 bulkhead is test fit the fwd and aft sections together with the bolts. I found the spacers and squared off their edges. I couldn't find any hardwood that I could get thick enough, so I made some more spacers from the left over aileron tubes. I drilled out the hole for the attach bolt and then reamed the 1/4 inch reamer through the hole way so that the holes line up. Then I put it all together.
