Brief Description: F-704 Bulkhead - Cover Support Ribs 4
I riveted on the cover support. First I put on the bolts, and per the drawing the bolt is too long. The shoulder of the bolt shows thru past the washer. So I put a thin washer on the other side under the head of the bolt.. Then rivetted. Just normal rivetting and bucking works fine.
