Brief Description: F-704 Bulkhead - Fit control stick base/ mounts 2
I bought the washer wrenches and they are a great help placing washers in this location. I had previously used thin pliers and tweezers, but these washer wrenches are worth the $27 bucks.
I bored out the control stick bushings to 1/4 inch using the same reamer I used earlier on the aileron control horn. This time instead of squeezing the bushing in a vice to hold it I put it in my drill chuck. This worked a lot better because there is no chance of over squeezing it and flattening it.
I used Boelube and there is not much friction. Easy to bore these out.
