Brief Description: Firewall - Clecoe all the parts 5 Fuelpump Double
Then there is this fuelpump doubler plate that has to be cut out and many holes drilled. I measured and scribed the holes using the digital micrometer. Using it like an awl makes an accurate scribe line to locate holes.
Not sure I'll need this because I'm planning on a fuel injected engine. But I'll drill it and prime it for now.
