I re-installed the bellcrank back into the wing. By the way, this is the RIGHT wing, not left. You can see the main bracket replaces the bottom Van's bracket and there is a little strap bracket attached to a bolt on the top bracket that will eventually attach to the servo. The control rod with bearings is included also.
I used AeroShell #6 grease on the brass bushing and bolt per drawing. This will just sit and wait until wing to body join. I'll put the servo in prior to closing the bottom skins.
