I installed the aluminum bushing inside the three nylon washers. I checked to make sure the hinge bolt didn't hit and it was clear. And then I checked the angle of motion from neutral to full up against the stop and it measured 30.4 degrees, which I believe is a couple degrees short of maximum and well within designed range.
