RV-7A Construction Log
Date:  3-5-2009
Number of Hours:  1.00
Brief Description:  Push Rods - Large Pushrod Bellcrank to Stick 4
Then I set up my little drill guide that holds round stock for perpendicular drilling and drilled the holes. I drilled them #40 first and then #30 as a second step. I deburred both sides of every hole. Then I primed all the parts and riveted them together. I mixed up which end cap goes on which pushrod but my hole patterns were so similar that they seemed to fit on any rod. The long drill in the photo flexed to much and I ended up removing the spring and pushing the drill all the way into the chuck with only 1/2 inch revealed for drilling.
Setup for drilling
Setup for drilling
This little jig works pretty good for round stock
Pushrod ends w/ bearings.
