Brief Description: Push Rods - Large Pushrod Bellcrank to Stick 1
I started making the push rods today. First I made the fat one which is the long pushrood that goes from stick to bellcrank. I took inventory of all the parts and discovered I'm missing one of the bearings. I guess I'll ask Van's for it. Then I cut the fat push rod to length but with 1/16 longer. I used a mitre box and hack saw. The box helped keep the blade square. I sanded both ends on the belt sander using the mitre guide to ensure the end was square. I sanded both of them to exact length.
