Brief Description: Ailerons - Hinge Bracket Issue 6
So the final result is much improved although still tilted in slightly. But I have plenty of back and forth movement so I should be able to align with flap fine and insert washers as needed. The whole job took only a couple hours this morning. There is no damage and an improved hinge. So I'm glad I did this.
