Then I laid the aileron flat, weighed it down to install pulled rivets to hold the counter weight pipe. I put a level on it to see if it was straight and to ensure it stayed straight. Not sure what I would do if it wasn't. I sprayed primer in all the holes and onto my pulled rivets in hopes of isolating the aluminum from the galvanized pipe. I pulled the rivets. Easy as pie.
