Here are photos so you can see my construction technique. I use screws not nails so I can take it apart and re-use it. I tried to keep in within 24 inches wide and below 5 feet high. The cradle is 96 inches long. Seems okay. I'm using pipe insulation tubing for padding. I might use carpet later.
