Brief Description: Main Skins - Debur, Dimple Top Skins, Frame 1
Now before I proceed with the Leading Edges and before I mount LE and Tank to spar I'm going to prepare the lower skins and frame because now is the time.
I started working on the main skins. First thing was to remove the blue stuff and debur. I discovered I could remove the stripes of blue stuff while the skin was hanging on the wing frame. Then I take it off and remove the blue stuff off the back, then I put it back on the frame and deburred the back side. It was easier then doing it laying flat. I used a pipe to roll off the blue stuff, because my brother showed me it works well.
