Brief Description: Tank Assy - Close Up Access Plate 2 & Hex Screw In
I smeared a layer of Proseal on the opening interface space. Installed the cover plate. Used a couple awls to align the holes and installed the screws. I used the special hex head scews because my brother did and because guys on Vans Forum recommended that these are easy to remove if you ever have to. You can get these screws at:
McMaster-Carr 562-692-5911 #90107A010 Type 316 Stainless Steel Flat Washer size: 11/64 ID, 3/8 OD, .024-.038 thickness #92200A194 Mil Spec Socket Head Cap Screw Stainless 8-32 Trhead, 1/2 length MS 16995-26
