Brief Description: Leading Edge - Prep and redo Inbd Rib 1
My tanks are done and the Proseal is drying so I start up again on the leading edge. I decided my inboard ribs that go under the joint plate are not drilled correctly. The holes are to close to the flange radius. This could cause cracking. So I've ordered two new inboard ribs. I have to re-assembly the leading edges for the purpose of re-drilling the inboard ribs and for mounting the landing lights. Then I'll prime and rivet.
But before I re-assembly I decided to debur and dimple all the holes.
