Brief Description: Tank Prep - Fuel Vent and Return Lines 1
I prepared the tubing runs for fuel vent line and fuel return line. I worked the tubing to try and get it straight. I decided to dump the fuel return into the 3rd inboard bay. I put flairs on the ends. This turned out to need some finesse. First flair was way too big. Turns out there is a stop on the tool that I didn't notice at first which helps define how big the flair will be. I put together the ribs and skin but clecoed on just one side to assist in defining the tubing runs.
