Brief Description: Tank Prep - Fuel Caps Locate and Drill
I located and drilled the fuel caps to tank skin. I clamped them to the skin and tried very hard to get the reviel showing around the hole to be exactly the same. I think I did. I had hallucinations about it. I drilled all the holes and countsunk the cap flange to accept the skin dimple. I made the two brackets that will later hold the vent line.
