Brief Description: Tank Prep - Access Plate Counter Sink, Rivet
I finished the access plate. First I enlarged the hole to be the same as the hole thru the reinforcement ring. Then I countsunk all the rivet holes and dimpled the rib. I riveted on all the platenuts.
Dimpled the Rib, Countersink the reinforcement plate
