Brief Description: Tank Prep - Attach Angle Final Fit 3
The final fit is good (not perfect). Perfect is the enemy of getting it done. I can see I'm going to have to carve out a couple places for the shop heads of rivets to fit. I made the holes per drawing and match drilled the holes through the rib and through the T-410 reinforcement plate. I did the outboard T-410 also. I checked to see if the flop tube fitting and nut will fit and I'm not sure. So I will check more and maybe have to use flush rivets.
