Brief Description: Tank Prep - Attach Angle Nose Flange 2
I made the flange that goes on the rib into the rib nose the same way. I traced the T-410 curve onto the angle bottom and made a line around its perimeter to capture the shape. Then I rough cut it on the band saw and sanded it to final shape on the belt sander. It takes a little longer to sand this in order to get just the perfect fit into the rib nose. Finally I polished the angle on the scotch brite wheel.
