Brief Description: Rear Spar - Trim off in board piece
I used the band saw to make a rough cut and removed most of the material. Then I clean up the edge and bring it to within 32nd accuracy using the belt sander. And I polish it off on the scotch bright wheel. Process goes pretty fast and accurate.
