Brief Description: Attaching Wings to Fuselage 5 Left
I put the left wing on. It took half as much time as the right wing. I did not waste my time with trying to freeze the bolts. I did brush out the holes with lubricant. And the bolts went in with taps from a hammer. I did the top for bolts first using tapered pins first and then did the bottom four bolts just straight in.
I tried to torque them. The top four were easy. The bottom four were again difficult to torque because I couldn't get a good hold on the nuts. But they are tight.
