Brief Description: Elevator - Left Trim Tab Finished
I finished the trim tab per plan. Trailing edge of trim tab is straight with elevator trailing edge. I did not have any waiver or twist in the tab to correct. It came out straight. Small gap between elevator tabs and outboard trim tab is not quit parallel, but close and flush revits give plenty of clearance with minimum gap. Inboard line of tab is just slightly farther out than inboard line of elevator, but not measurable. Gap underneath between tab and elevator is uniform distance. Overall I give this trim tab a B..
