I back riveted the skins to wedge first using the back rivet tool, then flipped and used the flush rivet set, and then switched back to the back rivet set and then again the flush set. Result is iffy (see next log entry). Black stuff came up through the holes and I carefully picked it out with a sharpened dental. The trailing edge is straight, but rippled.
