The top cowl goes back on and the hinge gets drilled.
Put all the pins in and everything fits pretty good.
I've got a tight fit at the back that will need to be widened before I glue the hinges on. The gap behind the prop is about 1/8 inch. The top cowl is level with the spinner. From the front the cowl looks centered about the prop but there is no way of really measuring because the cowl is rough.
