So I've been chasing this high EGT and finally solved it. It wasn't high at idle, but it would shoot up when I gave it full power for take off or when I gave it a lot of fuel for climb during flight. So it is going lean, probably a partical fuel blockage.
I tested and swapped plugs. Wasn't the plugs. I swapped the EGT probes. Wasn't the probes. I cleaned and swapped the injector nozzle. That's it. After cleaning the nozzle the next flight all temps are perfect.
While I had the injectors off I did a fuel flow test of the fuel distributor or "spider" as some call it. And the findings were great. The same amount of fuel comes out for both cylinders 1 and 3. I did the test by collecting fuel in cups. I pushed mixture full in so fuel could flow. Throuttle out. I turned on fuel pump and then slowly pushed throttle in. This lets fuel flow a little at first and then more as you go to full throttle. Then back to cut off. I measure the fuel and it was the same in both. Good thing.
So I put the nozzles back on, but switching 3 into 1 and 1 into 3. This way if 1 became hot I knew I had a bad nozzel. If 3 became hot something besides nozzle is the issue. But neither were hot. Problem fixed.
