RV-7A Construction Log
Date:  3-29-2019
Number of Hours:  1.00
Brief Description:  Hot Cylinder #3 1
One pickup from the first flight is to cool cylinder number 3 CHT. It was running about 30 degrees hotter than the others. After research on the forum I was led to noice the aft side of cylinder three has the baffle right up against the cylinder and there are no fins there so no air can flow thru. I removed the baffle and hammer formed a dent to allow air thru. I sprayed it with paint so it won't get corrosion and reinstalled the baffle.
Fixed now #3 is often the coolest cylinder.
No air can get thru
No air can get thru
See fins come flush with cylinder
Need to make a dent here
