Time to install the wing tips. I can't easily configure the ailerons without the tips. Way back when I had configured the ailerons. Then used them to configure the wing tips so that the tips match. But then the aileron moved for painting so I need to make sure it still lines up with the tips.
And them hopefully the flaps will line up with the ailerons.
So I examined the wiring. Added a few zip tips ties. Plugged in the lights.
I vacummned out the wing as much as I could. I didn't see anything in there except a few cobb webs. No bugs. No mice. No birds. No tools.
The left wing went first because the wiring was easy.
