Next trick is to attach the wings to the fuselage. This means insertiving the close tolerance bolts. This is the one task most feared. It is a task of no return. I've heard you can never gracefully remove these bolts. So when I started I was worried and stress about this. I've heard use lubrication; Use dry ice to freeze and shrink them; Use bullet bolts: All of which I am armed with.
