I put some heat shield on the lower cowl. I applied the aluminum foil that Van's sells. It is sticky back. I cleaned off the paint of the lower cowl with alcohol and stuck on this foil. It really sticks. Part of the trick to making it stick is in using a rubber roller to squeeze out all air bubbles and push the sticky side down really hard.
