I'm installing the sun shield now. Might as well. Easier to do it on the bench then installed. This is the Kruger Shade. You can get them from Spruce or Van's
Removing the vinyl from the plexiglass is hard. Then removing extra sticky goo requires WD-40 again. Finally I got the bubble clean. I have a couple scratches here and there. Darn. Next time I should take better care of the canopy. I even scratched it today moving it around on a piece of cardboard. It seems fairly soft and prone to scratching.
First thing you do and is mark a centerline down the outside of the canopy with tape.
