RV-7A Construction Log
RV-7A
Cowls Finalize Hinge Pins
I had to redo the hinge pins on my cowl to make sure I had all stainless steel and that they all worked and closed the way they are suppose to.
Also I have to repaint the lower cowl strip. So I put the cowls on and got all the pins working.
And I marked where to repaint the strip. This time it will be correct.
Need to repaint the stripe
Finalize all the hinge pins
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
