RV-7A Construction Log
Date:  5-6-2018
Number of Hours:  0.50
Brief Description:  Tail Installation for Final Time 5
As I bolted on the vertical stabalizer I tagged the nuts with latex.
I discovered that my wire for the tail light was 6 inches too short. I must have pulled this wire thru to much when I worked on the front end connectors. So I had some wire. But this also means a connector. This connector will ride in the bottom of the rudder.
