RV-7A Construction Log
Date:  3-25-2018
Number of Hours:  1.00
Brief Description:  Panel Install 2
As I connect wires to the panel I'm making adjustments so the panel can be removed.
1. The USB power wires need a connector.
2. I installed the key switch. I also left a 12 Volt wire here for future use. It comes from #15 CM.
3. I left a 5V wire available on he left side behind the key.
4. I ran an extra 12V wire down the center of the fuselage to the cargo area. It can be used for dome lights. It comes from #15 of CM.
Extra 12V wire for future use
