RV-7A Construction Log
Date:  3-24-2018
Number of Hours:  0.50
Brief Description:  Control Module Comm and Transponder
Installation of all the wires and components from Advanced Systems continues. You can see the CM (Control Module) now has Backup Battery, Backup EFIS, AP Servos, Control Sticks, Flaps - Trim, Front and Rear cables connected. I have run all the wires for these pieces to the CM and built up the connector.
I have started experimenting where to place the Dynon Comm and Transponder. I've decided to run to angles across the bottom of the ribs and use them as a frame to attach these to.
For each of these I made COAX RG-400 cable to run to the antennas.
Control Module
Control Module
Dynon Comm & Transponder
