RV-7A Construction Log
Date:  3-26-2018
Number of Hours:  1.00
Brief Description:  Air Vents 1
I should have attached these air vents a long time ago. The Advanced Quick Build panel caused me to buy the metal air vents. I now find out I need platenuts on the side brackets and there is barely room for tools to attach these. I made a mess of the brackets applying a couple platenuts, but the screws are in and don't need to come out now. You can't get your fingers behind the tubing to attach these. This requires the platenuts. I spent 3 hours trying to get this done yesterday.
CORRECTION: But tonight I figured out a 5 minute way to attach them. Just take them apart and attach the plate all by itself then insert the vent pieces and tubes. Dahahahahah. There is no problem putting on these plates if you just disassemble the ball valvue from the plate.
