RV-7A Construction Log
Date:  2-2-2018
Number of Hours:  1.00
Brief Description:  Trim Servo wire bundle and connector 1
Time to start doing the wire bundles that plug into the Advance System Module.
I decided to start with the Flaps and Trim Servos because all the wires I need are present. I had already done the connector for the autopilot servos.
Basically you:
1) Cut all the wires to the right length. I bit scary because you don't want to make it too short.
2) Put on sleeving and shrink wrap tubing now before you remove insulation.
3) Push he sleeve and shink wrap up out of the way
4) Remove insulation
5) Crimp on d-sub pins
6) Carefully follow the pin map and plug the pins into the numbered holes. Don't screw this up.
7) Test anything you can, which isn't much
8) Cover it up and add the connector.
Wires ready with pins
This is how I hold sleeve out of the way
Follow pin map closely
