Next I mounted the Engine Control Module (ECM). It is a hub for all the engine transducers. This I mounted on the side of the rib just forward of the subpanel. Later when the skin is on top of these things it will be hard to service. So I'm keeping that in mind. Every mounting screw is using a platenut because in service will be easier than if I use a nut and bolt.
The ECM has to big connectors. One with brown wires is for all the EGT and CHT transducers. The other is for all the other engine measurement things.
As I proceed I'm slowly figuring out where my main wire runs will be.
