RV-7A Construction Log
Date:  1-20-2018
Number of Hours:  1.00
Brief Description:  Advanced Control Module Mounting 2
You can see where I ran the ground to. I ran it to the only bolt penetrating the firewall with the grounding block on one side. I probably don't need the grounding block since I'm use the ACM hub.
Mounts pilot side subpanel
Grounded
Grounded
