The Advanced System Panel incorporates a power distribution system. It does more than just power. Everything plugs into it as a hub. It is an interface between the airplane wiring and the panel components. It is also the circuit breakers, or in this case fuse box. Notice it use auto fuses. This should make wiring easier and cleaner.
