RV-7A Construction Log
Date:  9-1-2017
Number of Hours:  1.00
Brief Description:  Rocker Switches 1
In an attempt to help get my head into wiring I bought some cool rocker switches. These have internal lights so you can see what they are. And the faceplates are customizable and changeable. The have a second internal light that turns on when the switch is on.
I ended up sending these to Advanced Systems to use in my panel. They did a great job and helped me figure out a few things.
Major point of learning is: For the experimental I don't have a tail beacon to indicate HOT PROP. i thought I need some white tail light to do that function. But Advanced System told me, do it with the strobes. So the final switches are like this.
1. Battery- Can't turn on Alternator unless the battery is first turned on.
2. Alternator -
3. Aux Fuel pump
4. Avionics master
5. Strobes
6. Landing Lights
7. Wig wag switch
8. Navigation or Position lights (Red, Green, White)
9. Heated Pito
10. Flaps
Kit of rocker switches
Switches not in order
Don't look at order.
