The panel will be IFR and so it needs two independent gyros. One will be the Dynon Skyview Touch large 10 inch main screen. The other will be the Dynon D6 EFIS. The D6 requires Pitot, Static and AOA input. I checked with Dynon and they said to route the lines. But they didn't mention AOA line. Maybe I don't need all three. Oh well, I routed all three today.
The static line is easy because I had already made provision for it to route forward. It comes from the two holes in the aft fuselage forward under the longeron.
The pitot and AOA come in from the wing. I started from the platform where the ADHRS will go and ran the tubing forward. I cut it at the wing root and added a splitter on both lines. Then I ran the Pitot and AOA lines forward.
