I'm headed down final assembly of the engine and its components. I'm tackling all the Dynon engine transducers. And at the same time assembling the final components of the engine headed towards finally installing the exhaust system.
Here I decided to install the rear baffles and oil cooler for hopefully the last time. I installed both hoses. I tightened them about 1/8th turn after contact. I did use thread seal althought you aren't suppose to need to.
