Before I could paint the baffles I needed to cut holes for cooling blow tubes.
I called the Alternator manufacture Plane Power and they said their alternator does not need a cooling blow tube. So even though I see some on other logs I'm not going to add one.
But the magnetos need cooling tubes so I drilled two holes and used the solid tubing from Van's. The tubes hold in place at the hole and with one Adel clamp.
